'68 Marshall 100w chassis blueprints
Just like the 50w Marshall chassis blueprints and the Marshall 1960b 4x12 cabinet blueprints, here's the 100w Marshall chassis blueprints. Once again, I'm only making this kinda stuff available so folks who have the means and the knowledge to build there own stuff can have something to work from....Like I mentioned before, there seems to be a lack of this type of info available on the net, so I figured I'd fill the void so to speak.
About this blueprint....A good majority of the dimensions were taken from an original '68 12Series Super Lead. In honoring George's wishes, none of the dimensions were taken from George's 100w chassis that he graciously makes available....BTW, unfortunately I don't own one of his chassis since it would have been nice to use just as another cross-reference though. Anyhow, I hope these will come in handy when someone decides to make their own chassis. As usual, comments, corrections, or suggestions are welcome.
- VelvetGeorge
- Site Owner
Re: '68 Marshall 100w chassis blueprints
Excellent drawing! Looks just like my '67 and '68 Marshalls.
Thank you very kindly George.
- VintageCharlie
Thank you very much for sharing these! Looks great! This might come in handy
thanks a lot for the work!
Hey no problem....Hopefully, they'll be of some use to you guys.
- bill bokey
Hi,
I downloaded the file but it's corrupted. Can anybody repost it ?
Thanks,
Bill
Thanks,
Bill
- VelvetGeorge
- Site Owner
Gone away like so many attachments on this board after our server attack in 2014. Hopefully someone will repost.
- bill bokey
I thought it had something to do with the server issues.
Hi all , just saw the post , luckily , i saved it
here's the 100w 68 :
https://www.mediafire.com/?5nqq7tu6in3xm3b
and the 50w drawing :
https://www.mediafire.com/?zi4zuz6plsx8nqr
Hope it helps !
Hope it helps !
- bill bokey
Great stuff ! Thanks frenchie !
Do you have the original dwg file ?
I never posted drawing files (.DWG) or cad/cam files for the chassis's just pdf's.
- bill bokey
For some reason when I opened the pdf Acrobat displayed a .dwg name.
Tazin, do you still have the dwg file ? If so would you mind sharing it ?
The pdf's were created from cad drawing files (.dwg) so that's probably why you saw a .dwg name. Normally I don't post cad/cam files since I'm just trying to 'help out' and not do all the work for people. What I have done in the past is tailor a chassis drawing to suit someone's specific needs based on the components they'd be using to build an amp. If this sounds like something you'd be interested in then drop me a PM.
