Only differences from the original will be Larry style grounding throughout, even power tube cathodes! I'm going to run them directly to grounding point 5.
I'm done with the heaters, so now the fun begins.
Before I go on, I have two questions:
1) I was planning to run the OT secondaries (blue, green, yellow) between V6 and V7 since that gives me the shortest path. However, they will be running closer to the PT that way. Is that a problem? Could it induce hum somehow? I was unsure whether to have the OT primary or secondary side closest to the PT, but opted to have it as pictures, as I could then run the OT primaries directly between V5 and V6, plus I could run the secondaries a short distance to the impedance selector.
2) As I said, I am running the power tube cathodes directly to grounding point 5. However, if I can, I would still like to install 1 ohm bias reading resistors. So I take it I still have to link pins 8 and 1, and have the 1 ohm resistor between pin 1 and ground, or could I have the 1 ohm resistor off of pin 8, and then link pin 8 and 1?
