Wire lacing tutorial
BrianH
Post by BrianH » Thu May 07, 2009 10:14 pm
Been asked a bunch of times to show I how lace my wire bundles like the old Marshalls, Hiwatts, etc. Here's how I do it which I think is vintage correct.
Get some lacing cord or even some thin, stripped wire insulation. I'm using old stock RS lacing.
Bundle of wires to be laced:
http://kurtsequipment.com/lacing1.jpg" onclick="window.open(this.href);return false;
Wrap one end as you see fit. I like to tie a knot, wrap around the bundle a few times, then pull the lead through one of the loops:
http://kurtsequipment.com/lacing2.jpg" onclick="window.open(this.href);return false;
Pull the lead wire to where you want the first knot, and loop the lead under the bundle from the right side:
http://kurtsequipment.com/lacing3.jpg" onclick="window.open(this.href);return false;
Grab the lead on top of the wires and twist clockwise to make a loop as shown:
http://kurtsequipment.com/lacing4.jpg" onclick="window.open(this.href);return false;
Take the lead wire and feed through the loop:
http://kurtsequipment.com/lacing5.jpg" onclick="window.open(this.href);return false;
Pull the lead away from you to make a knot, then pull the lead straight up in the air, then back + forth from L to R to cinch the knot super tight:
http://kurtsequipment.com/lacing6.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing7.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing8.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing9.jpg" onclick="window.open(this.href);return false;
Pics for knot #2:
http://kurtsequipment.com/lacing10.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing11.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing12.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing13.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing14.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing15.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing16.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing17.jpg" onclick="window.open(this.href);return false;
http://kurtsequipment.com/lacing18.jpg" onclick="window.open(this.href);return false;
and continue to the end of the bundle! Do it a few times and you'll get the idea.
Brian
thousandshirts
Re: Wire lacing tutorial
Post by thousandshirts » Thu May 07, 2009 10:38 pm
Great post, Brian! :shock:
BrianH
Post by BrianH » Thu May 07, 2009 10:59 pm
Thanks, man. Don't mind the dirty fingernails. Was doing some gardening :lol:
sah5150
Post by sah5150 » Fri May 08, 2009 12:51 am
Awesome post, Brian! Always cool to see how people do stuff!
On another note, I went to your custom board site. Can you cut that perf board to any size? I need something custom and if you can cut that board to any size, I'd be interested in buying some from you. I don't need the turrets staked, just empty perf board... Lemme know here or via PM.
Thanks,
Steve
BrianH
Post by BrianH » Fri May 08, 2009 1:57 am
Hey Steve, I'm limited to 3 1/8" by 11 7/8" at the moment or smaller. If you need smaller, no problem. Bigger I can't do yet as I order either precut or close to precut.
What size were you looking for?
thanks
Brian
el34on11
Post by el34on11 » Fri May 08, 2009 9:58 am
Awesome tutorial Brian.......Thanks for posting this....... :D
Derrick
LesPauls and Marshall's
BrianH
Post by BrianH » Fri May 08, 2009 1:15 pm
Another pic - from my JTM45 build.
sah5150
Post by sah5150 » Fri May 08, 2009 6:26 pm
BrianH wrote:Hey Steve, I'm limited to 3 1/8" by 11 7/8" at the moment or smaller. If you need smaller, no problem. Bigger I can't do yet as I order either precut or close to precut.
thanks
Brian
Brian,
I'm looking for 3 1/8" by 22"
If you can help, lemme know...
Steve
S.Marshall
Post by S.Marshall » Fri May 08, 2009 6:45 pm
thanks
Brian
Brian,
Steve
Brian is making one for me that's about 15". You just need to send him the material you want.
-Steve
BrianH
Post by BrianH » Sat May 09, 2009 10:59 am
22" :shock: That's a big board!
Wish I could help Steve, but all I have is much smaller than that right now. Sending me the material is an option. I've had people do this before with other colors, etc..., as S.Marshall is doing now :wink:
Brian
sah5150
Post by sah5150 » Sat May 09, 2009 2:23 pm
thanks
Brian
Brian,
Steve
Cool - where did you get the perf board from? I already have un-perforated board...
Steve
BrianH
Post by BrianH » Sat May 09, 2009 2:26 pm
I think I'm being sent un-perf'd material, Steve. I can make into perf board or whatever you'd like.
Brian
S.Marshall
Post by S.Marshall » Sat May 09, 2009 2:43 pm
Yup, I'm sending un-perfed material. I didn't want the fully perfed look for this one. Just staked to my specs.
-Steve
mwm523
Post by mwm523 » Wed May 13, 2009 12:58 pm
Back on the lacing topic... Anyone know where I can get some of this type of lacing material? I would like to use it in the new JTM45 I've just started building.
-Mike
BrianH
Post by BrianH » Wed May 13, 2009 5:56 pm
Sorry, no lead on the source. I have some old stock stuff
Steve,
Just wanted to let you know I now have material in stock to do any size board... JTM45, JTM45/100 main and cap boards, superlead, etc. It is terrific-looking, domestically made material that is slightly lighter in color than my red material (which is almost gone).
thanks!
Brian
