jtm45 squeal
jbzoso2002
jtm45 squeal
Post by jbzoso2002 » Thu Feb 03, 2005 9:01 am
i get a squeal on vol 1 input 1 when vol goes past 7
i removed 100 pf from vol 1 pot because amp was too bright
this is a jtm45 built with jtm45 upgrade kit heyborer transformers
mm 3.3 choke sound great except for squeal
has any body seen this before ????
thanks jimmy 8)
Post by Flames1950 » Thu Feb 03, 2005 11:16 am
There are a few ways to get one to squeal. The one I ran into when I re-did my '78 2204 as a 1987 was that I ran the purple wire to the presence pot too close to the other tone controls' wiring, it needs to tuck under the board away from the other tone control wires.
jbzoso2002
Post by jbzoso2002 » Fri Feb 04, 2005 9:14 pm
thanks flames you were right :D
i moved the presance wire and now no sqeal :D
you guys are the goods !!!!!!!!!
well i gota go play my jtm45 :shock:
jimmy 8)
