Soldering PCB.... advice?
demonufo
Re: Soldering PCB.... advice?
Post by demonufo » Thu Aug 22, 2013 1:17 pm
60W isn't overkill if using a very small good quality tip, but really, it is way over the top.
I either use an Antex temperature controlled station, or a little standalone 50W Antex with smaller tips to keep the temperature down, and I work fast.
So I like purple, okay!!!!!!
catalin gramada
Post by catalin gramada » Tue Sep 17, 2013 2:19 am
Hi
A 25-30 w iron is all you need. most imoprtant to use a free oxide tip each time so use the sponge for each solder point. also is important to not overheat the tip. You can use a diode shunted with a switch to keep you iron in stand-by half power mode without burn or overheat the tip.
Catalin
Catalin
