I keep getting a ground hum from ALL my guitars. When I take my hands off the strings or bridge I get hum and then goes away when I touch it. Could this be caused by a grounding problem with my inputs?
I have a 68 Plexi clone.
Ground hum, inputs?
- rgorke
Ground hum, inputs?
- rgorke
Re: Ground hum, inputs?
I poked around with chop stick. The ground at the mains seems good to go. I have, in the past, done some futzing at the inputs and may not have them soldered to ground as good as they should be....cold solder joints, maybe.
When I touch the chassis the buzz goes away as well.
Also tested with different amp, guitar, etc.
