DIY JCM 800 2204 on JTM45 chassis
Re: DIY JCM 800 2204 on JTM45 chassis
Good luck with a new build. I already seen some photos on your site. Every part unique as always, but are you going to use 560 pf instead of 470 pf ? And as I remember you already used Sozo Vintage's and Mullard Mustard's caps... Do the Mullard's sounds THAT much better than Sozo even with 10% tolerance?
