Board in - Please check my work!!
- Megachunk
Hi All,
Thanks for all your help on this thing, it's been invaluable and I wouldn't have made it this far w/o all of you.
The board is in wired up and I tested voltages. Some seems fine, others were a bit wacky, but I figured i wasn't getting a good reading on my DMM. I'll post those tomorrow. ANYWAY, got tubes in and fired up. Bias was very low. Here's what I found out:
There was a big hum, which makes me believe its a grounding thing. I probably have my jacks jacked, becasue now I can olny fit 2 jacks in with the new board. (any diagrams on wiring 2 jacks, and where to run ground, one for I and one for II - they can both be hi gain) V2 is a bit microphonic, but pins 1 and 7 are tied together (is this right?) When I turn up the prescence, it hums louder. I did plug my guit into it, and the guitar was grounding when I touched it. and a very quiet, feeble guitar sound came out. I do need to tie pin 6's together to the board, but they seem to be connected indirectly through the 1/2 power switch.
Anyway, when you dudes have a moment, can you look at my pix and tell me if anything looks funkified? I mean in bad way.
- (207.05 KiB) Downloaded 95 times
- (112.8 KiB) Downloaded 275 times
- (117.33 KiB) Downloaded 249 times
- (110.33 KiB) Downloaded 1631 times
- Flames1950
- Flames1950
- Megachunk
- Flames1950
- Megachunk
- Flames1950
The output sockets need to be left with pin 6 wiring intact. I'm looking at the second preamp tube socket only. The JCM800 may have had that resistor on the PCB instead.Megachunk wrote:There was no resistor there to begin with. Maybe the tech who installed the 1/2 power switch took it away. I'll put one there tomorrow. Should I still tie those pin 6's together on the output tubes together?
- Megachunk
Yeah, it's a long skinny chassis! I'm thnking the jacks are a big part of the prob. There nothing running to ground on them right now.Flames1950 wrote:How did you end up doing the inputs with only two jacks? It's obvious why you had to do it that way, man there is no room to put anything in that amp on the fron side!!![]()
- Megachunk
Got it working! I had a misplaced wire on the pots, grounding the jacks and doing that V2 resistor must've done the trick! For whatever reason, my bass pot is doing very little. It's hooked up right... Is there a cap I can add to beef up the bottom end? I do play out a 4-10 cab. All other pots are fine. It's a tiny bit hummy, but I'm sure there's some grounding I can do to help eliminate it. Can anyone help me with biasing it? I just need to know where the ground lead goes. Is it center tap? Not sure which it is. I test on pin 3 of the output tubes, correct?
BTW, even now it blows the PCB out of the water! What crunch!
