Link to SLP PTP board installation instructions..
Hey guys. I just ordered a PTP board, master volume, effects loop, and a new output transformer to spruce up an SLP that I picked up. Is there a link to download the PTP installation instructions?? I'd like to get started removing the printed board..
- axeman
Re: Link to SLP PTP board installation instructions..
http://metroamp.com/wiki/index.php/Cate ... structions" onclick="window.open(this.href);return false;
That's a link to the entire amp kit instructions. I was wondering if there's specific instructions for just replacing the PCB board in a Marshall 1959SLP.
Hello? Anyone? There is no link to specific instructions on installing a PTP board into an SLP ???
- demonufo
Not that I'm aware of. It's not that difficult using the full amp build instructions though. Just wire up the board as per instructions, and then follow a layout.
So I like purple, okay!!!!!!
- Mars Hall
A good layout is all you really need.
http://metroamp.com/wiki/index.php/100_ ... sis_Layout" onclick="window.open(this.href);return false;
Load the board with all components and leads. Then wire it into the chassis. If you have any questions on "best practises" then ask here.
