Sozo's: Regular and Vintage... which ones for what amp?
Roadrunner
Post by Roadrunner » Tue Jan 20, 2009 9:39 am
I remember reading a post from the Sozo guy that the two kinds of caps he makes were suited for different types of amps... something along the lines of, "The "vintage" caps are better for JTM45's and the regular ones were better in Plexi's." ... or something like that.
I searched but I can't find the thread that was in, can someone find it and post a link?
Thanks in advance!
Achieve the Possible!
samwheat
Re: Sozo's: Regular and Vintage... which ones for what amp?
Post by samwheat » Mon Mar 30, 2009 6:10 am
I just bought a set of premium caps for my Hendrix clone. Waiting to try them out.
Post by Roe » Mon Mar 30, 2009 6:28 am
john at sozo recommended premiums for the jtm/bass circuit and standards for the later lead circuit (33k/500pf, .68uf etc etc)
Scumback Speakers
Supporting Advertiser
Post by Scumback Speakers » Mon Mar 30, 2009 11:38 am
Roe wrote:john at sozo recommended premiums for the jtm/bass circuit and standards for the later lead circuit (33k/500pf, .68uf etc etc)
I think John said that the premiums didn't have quite as much bass as the standard caps, so they worked better in the JTM circuit to reduce the bass response of that circuit. When I compare my two 50w lead spec amps, the standard SoZo caps have more bass than the Vintage SoZo caps, so he's right about what to use them in.
Post by Roe » Mon Mar 30, 2009 1:53 pm
the premiums also have less high highs. they simply have a narrower bandwidth
flemingmras
Post by flemingmras » Sun Nov 15, 2009 1:50 am
I spoke with John on his Vintage vs Standards, and basically the Vintage was purposely made with a higher ESR rating (Equivalent Series Resistance) than the standards. This would amount to the narrower bandwidth that you guys are hearing.
Roadrunner
Post by Roadrunner » Sun Nov 15, 2009 8:34 am
That's good info... thanks everyone!
