i removed all that put in a ptp 50watt lead board 3 new 50/50 caps
mm plexi opt 10h choke new pots new input jacks x4 in a standard
1987 layout. biased fine fired up with weird sounds. i found that i was
missing a ground fixed that then it was cutting in and out. found a couple
of bad solder joints in the front of preamp. fixed that amp played
but lower 2 input jacks didnt work but i played through the amp for
2-3 hrs sounded ok but with a slightly different overtone on distortion
after a long sustain. rewired the input jacks now amp doesnt play
can hear hiss and hum but no guitar sound bias is still normal
also power trans got pretty hot after the 3 hr playing but it is
20+years old. ive been checking conetions and layout but am
stumped????????????? any sugestions
