Help Please..Question regarding board resistors...
- ZEPFREAK
I'm presently building a board for a 50 watt lead...I was going to try out Vishay Dale metal film resistors because of their noise reduction and value consistancy..I was wondering if I can replace all of the carbon and metal oxide resistors on the board with Vishay Dale metal film..And do they all have to be the exact values..I see a few are 820 ohms..And I think the Vishays are 825 ohms..Thanks for any input..Randy
Has anybody seen the bridge?
1979 Gibson Les Paul
SLP Reissue with 69 Metro board/MM trannys
Marshall 4X12 with greenbacks and 30's
- Flames1950
You should be able to substitute the Vishays for any of the resistors you like, as long as the wattage rating of the resistor is correct for each type of circuit.
You shouldn't have any problems if the Vishays are slightly off. Your example of 820 vs. 825 ohms: even if the 820 ohm resistor had a 5% tolerance, that's a possible variance of 41 ohms either way!! I can't imagine you'll notice the difference (unless you're Eric Johnson......
Many people claim the vishay metal films sound warmer. Mohave uses all Vishay/Dale metal films. Theres alot more off values then the 825. The 220k are 221k, the 470R are 475R etc... So like Flames said its nothing. That 1% tolerance could make it anywhere from 816 to 833 while the traditional carbon films with 5% tolerance would make it from 779 to 861 and carbon comps with 10% tolerance would be from 738 to 902. See why vintage amps can sound so different?
- ZEPFREAK
Hey Thanks Flames and Billy Batz..I never go past either one of your posts without reading it!!..You guys are the best...One other thing regarding resistors if you don't mind..You guys said keep with the correct wattage rating..How about the voltage ratings..I heard overkill is ok..What's the lowest rating you could go with..Thanks again guys..Randy
Resistors arent rated in volts. A resistance doesnt just stop the voltage it has to release some energy that you measure in wattage I guess is a way to put it. Most of the board is fine with 1/2W though I use 1W for those when I use anything but carbon comp. Some people use higher wattage for plate resistors and cathode resistors.
- Flames1950
Most resistors are half-watt stock in guitar amp circuits, except the bigger 10K resistors in the B+ voltage line, they're 1 watters.
Many people like to bump all these up to the next level, ie. one watters in place of the half-watt resistors, and 2-watters instead of the one-watters in the B+ line.
Seems like Matchless didn't use anything less than a two-watt resistor, did they?
I have quite a few booteek schems that show people using high wattage resistors. Maybe theres something to that. It seems Ken Fischer made it a point to use a high 1k25W cement in place of a choke though a 5W would have been sufficiant. Ive also heard ****** say a 5W cement for the cathode resistor sounds creamy in Marshalls.
- ZEPFREAK
Wow...What a bone head I am..I must have been thinking of capacitors when I was talking voltage..Thanks for all the input..I'm going to go ahead and build with the Vishays...Let ya know how it sounds..Randy
By cement, do you mean those square, wirewound resistors that look like little cement blocks? (I'm guessing that is what the reference is, but I want to make sure)Billy Batz wrote:I have quite a few booteek schems that show people using high wattage resistors. Maybe theres something to that. It seems Ken Fischer made it a point to use a high 1k25W cement in place of a choke though a 5W would have been sufficiant. Ive also heard ****** say a 5W cement for the cathode resistor sounds creamy in Marshalls.
Also, is this all cathode resistors, or just certain ones?
What good is my wisdom
When there are no words to say
How I feel everday ?
