plexi kit, Dual bias trim pots???
joepete
Post by joepete » Sat Jul 28, 2007 1:46 pm
Hello, I am in the process of wiring the components to the board and noticed that I have 2 bias trim pots supplied, 1 is standup and the other is laydown type. It makes sence to have 2 bias trim pots so that you have a trim pot for each pair of tubes, but when I look on the various layouts they only seem to show the one standup bias trim pot. My question for you guys is that are both trim pots used in the plexi 100 watt 69 kit?? And if so, Where exactly does the other trim pot get installed? PLease answer in detail if possible and any good photos or quality layouts showing this would be great!
el34on11
Post by el34on11 » Sat Jul 28, 2007 5:29 pm
Hey........................
You only need one bias pot for your board................And you should use the stand up one and wire it like the instructions show.................
Check out this thread it explains it perfectly!!!!!!!! :wink: better than I ever could
http://forum.metroamp.com/viewtopic.php?t=12688
Hope this helps!!!!!!!!!!!
BTW sounds like your real close to firing it up........... :D
Derrick
LesPauls and Marshall's
