I recently got back at it and swapped a few bias resistors to get myself in what seemed like the right range to try setting the bias. I'm now getting a range on pin 5 of around -38VDC to -55VDC when I turn the bias pot with no output tubes installed. I've also got about 450 volts on pin 3. Seems ok right?
Here's my problem: when I install all the tubes, connect a speaker, and power it up to check the bias I hear quite a bit of fairly loud crackling and popping, so I turned it off. When I flip the power switch off I get very loud pop. This is loud enough that I worry about blowing a speaker. Clearly something is wrong and I'm looking for help in putting together a strategy for tracking it down. I'm thinking possibly I've got some bad solder joints
somewhere or maybe something is shorting under the board somewhere?
Obviously I should try pulling the board off the mounts and inspecting the underside to see if anything is shorting underneath. I know that you can check for sold solder joints with the chopstick method, but I don't think that's safe in this case since I may blow a speaker or worse. Should I power it up without the output tubes and check voltages throughout the board?
I have already tried a known good alternate pair of output tubes, but not preamp tubes (didn't have any spares, but could pull some from one of my other amps)...
thanks in advance!
Eamon
