Changing out the 16uF cap
darrell
Post by darrell » Fri Jun 01, 2007 2:58 pm
My mercury magnetics out put tranny came in and I have almost finished my board but i have one quistion ??
Insted of using the 16 uF atom can i just use another 10K resistor or something else? What would the trade off be also..The Vitamen Q caps where somthing i had so I thought they would be a good upgrade
Darrell
Wicksy
Post by Wicksy » Fri Jun 01, 2007 5:58 pm
whats stopping you from using the other half of that dual 16+16 can cap :wink:
Simon
darrell
Post by darrell » Fri Jun 01, 2007 6:22 pm
I have 16 uF atoms caps I was just woundering if I changed it to a another 10K what would it do to the sound of the amp Or should I opt for dual 16 uF like the 50 watter uses?? just looking for options and what it would do to the tone of the amp?I didnt know I could use it Humm.
Darrell
Oh on the M/M jtm45 O/P transformer I have a red brown black wire I know the brown is center tap but what vale does the red and black go to
Red V4 Or red V5 ?? Thanks again
Post by Flames1950 » Fri Jun 01, 2007 6:43 pm
You can't just stick a 10K in there without arranging for other filtering, and rearranging your jumpers under the board to accomodate the changes. Even going with a dual cap on the board with an extra 10K would require some jumper changes.
darrell
Post by darrell » Fri Jun 01, 2007 7:21 pm
Thanks flames Thats what I was after.
But i still need to know does the red wire go to v4 or v5???
The tranny is a Mercury Magnetics O45JT-16..
