Build Order ????
ChuckLogan
Build Order ????
Post by ChuckLogan » Tue May 01, 2007 2:51 pm
I am in the process of replacing my board and I have been reading George's JTM45 instructions and it says to attach the wires to the under side of the board . . then install board into the chassis, and then populate the board . . .
I am thinking it would be easier to populate the board outside of the chassis . . is there a downside to this ???
Was thinking:
Attach all connection wires (underside)
Flip over, install compnents on board
Then install board into chassis
Sound OK?
Post by Flames1950 » Tue May 01, 2007 6:27 pm
Sounds fine to me, I always populate the board with both components and wire before it goes into the amp.
ChuckLogan
Post by ChuckLogan » Tue May 01, 2007 7:31 pm
Thanks again dude . .
Yeah it's easier to get at the board when it is out.
PS - Flames1950 your build work is very clean . . your amps look killer!
rockstah
Post by rockstah » Tue May 01, 2007 7:39 pm
im with Andy.
my boards are fully populated and wires attached before they even go near a chassis.
then they go in and out a couple times ( a dry run ) measuring and cutting the wires.
Mark
Wicksy
Post by Wicksy » Wed May 02, 2007 7:11 pm
rockstah wrote:im with Andy.
Mark
+1 on that. Exactly what i do too.
Simon
