Here is the latest
Here are my readings on the pres, with only preamp tubes installed.
V1
1. 180
2. 0
3. 1
4. 3.25
5. 3.25
6. 231
7. 0
8. 2
9. 3.25
V2
1. 188
2. 0
3. 1
4. 3.25
5. 3.25
6. 319
7. 188
8. 189
9. 3.25
V3
1. 248
2. 226
3. 342
4. 3.25
5. 3.25
6. 236
7. 28
8. 43
9. 3.25
EDIT 2:53 pm
Update: A few words of advice to the paint by numbers guys like myself. Make sure the selector switch is clicked into place. The reason I was not getting any sound was due to the fact that the selector switch was not seated correctly on the 16 ohm setting.
The second word of advice: when reading Bias current on the 1 ohm resistors on pin 8 maker sure that you meter is set to millivolts(DOH!)
My amp is up and running, is very quite and sounds great, let the tweaking begin.
