So you are making your own perf board from a solid board?
Then installing turrets on it?
Lead or bass specs?
There are layouts of the board on Wiki.
http://metroamp.com/wiki/index.php/50_w ... board_lead" onclick="window.open(this.href);return false;
But if you are talking about exactly where each turret goes, what I have done in the past is layout the parts by drawing it on paper.
Once I am sure the parts will fit and everything looks good I taped the paper onto the board then used a awl and marked the turret locations.
Since you are using perf board I guess you could still use a paper layout but just install the turrets where they should go according to your paper layout.
Unless I completely misunderstood your question which is entirely possible.
