ptp in jcm 800 worked at first but now probs ???
Billy Batz
Post by Billy Batz » Tue May 17, 2005 1:15 am
The way you have it is reversed. The hi is on the bottum. That would be a problem but you also have the jack functions switched. You have the components that should be on the tips on the switches and vice versa. You can have them pointing any way you want as long as their wired up correctly which is just easier facing the "normal" direction. On a cliff type jack, when veiwing from the top and from the input side, the top left lug is the tip, the top right is the tip switch, the bottum left is the sleeve and the bottum right is the sleeve switch.
jbzoso2002
Post by jbzoso2002 » Tue May 17, 2005 2:12 am
:D :D :D dudes one and all you were right :!:
i didnt know these were switched in that way.
i rewired them pointing away from pots...................
wow i have super lead tone :shock: thanks very very much for your help
:!: amp sounds great . i paid $200 for a 2205 jcm 800 head
plus $350 in parts and thanks to your help i now have 2 smokin amps
thanks again jimmy :D
jbzoso2002
finaly registered
Post by jbzoso2002 » Tue May 17, 2005 12:07 pm
just got done playing the now 1987 plexi :D
i wonder what you call this anyway?
this thing smokes i never thought i would have an amp like this
for $550 :shock:
thanks again dudes :P
The right of the people to keep and bear arms shall not be infringed
jbzoso2002
one more pic
Post by jbzoso2002 » Tue May 17, 2005 12:09 pm
ant it cool :D
