Help with wiring
- Ricky Lee
Help with wiring
The wiring diagrahm references a ground wire for the right diode, does this go to the ground lug at the far right filter cap?
- Flames1950
Ground that wire on the upper left hand filter in the grouping of four cans, should be a ground lug there.
You can see what I mean if you get out George's Metro Tech CD, go to the 100 watt Images folder, and look at picture 100_5979.jpg where you can see the ground wires coming into the ground lug at that cap.
That power supply pic is a real nice close up shot to reference.
