Need Advice......Master Volume PTP Board Into 2203 Reissue!
Mattman
Post by Mattman » Sun Dec 02, 2007 2:38 pm
Hi all! Well, I am not all too satisfied with my 2203x reissue. After hearing an original 2203, I am actually a little bummed I spent 1800 bucks on the amp. I was thinking about dropping the MetroAmp PTP master volume board in, but I was also thinking about having the amp modded by Voodoo Amps. I know this is a MetroAmp forum, but I like getting input from as many sources as possible. Ok, here are my questions:
1) What will be the main differences between having the PCB board modded, and dropping in the PTP board? Will I notice a big difference? If so, in what?
2) Has anybody here dropped a PTP board into their 2203 reissue? If so, what differences did you notice?
3) I also want to drop in a new transformer. What transformer that Metro sells would be a good match for the 2203 reissue?
4) How much does it usually cost to have a PTP board installed by a good tech?
Thanks for any help you guys can offer me!
toner
Post by toner » Sun Dec 02, 2007 11:43 pm
I don't have much experience with the JCM 800 RI's (except to say that they are extremely bright) so this may not be of much help...
I'm sure a Metro PTP would help but there are a few things you can try before that. I'd start with good tubes and a bias adjustment. A lot of the RI's have crappy tubes and are biased pretty cold from the factory. A smaller bright cap or removing it completely should help too. A lot of the RI output transformers aren't very good sounding but that's not a cheap upgrade. I'm not sure about the 800 OT's though.
Do some searching here. I'm sure there are several people who have upgraded 800 RIs. I've done a ton of upgrades to a 1959 SLP and some are more cost-effective than others but there's always room for improvement.
rockstah
Re: Need Advice......Master Volume PTP Board Into 2203 Reiss
Post by rockstah » Mon Dec 03, 2007 1:21 am
Mattman wrote:Hi all! Well, I am not all too satisfied with my 2203x reissue. After hearing an original 2203, I am actually a little bummed I spent 1800 bucks on the amp. I was thinking about dropping the MetroAmp PTP master volume board in, but I was also thinking about having the amp modded by Voodoo Amps. I know this is a MetroAmp forum, but I like getting input from as many sources as possible. Ok, here are my questions:
1 the main difference will be that with a PTP board u have more freedom to tweak your sound. its alot harder to do on PCB board.
2. the is subjective and arguable. see #1
3. I'm sure George could answer that question for you.
4. depends on the tech. anywhere between 50-100 bucks and hour. for me it would depend on the amp in question. what it looks like etc.
Flynman
Post by Flynman » Fri Jan 11, 2008 5:49 pm
I had the same problem with my 800 2203 RI . I changed preamp and powertubes. That helped. Then clipped out treble cap on volume pot That helped. Now I am going to change the OT & the choke. Still trying to decide which OT to use. Thinking maybe MM drop in replacement with 3H or 5H choke. I think after that it will be pretty close to what I want out of it. You can go to Tone-Lizzard web sight for treble mods on that amp. Good info.
