Panama Solo Fast Lick. Suggestions?
jculb69
Post by jculb69 » Fri Feb 05, 2016 5:12 pm
I've found this lick in the solo for Panama hard to play to speed. I'm wondering if anyone has any picking pattern/phrasing suggestions. He plays a similar lick in Romeo's Delight and at the end of the solo for When it's Love. Below is the way I'm picking it.
d=downstroke
u=upstroke
h=hammer
p=pull-off
---------------------------------u7-------------------------u7----------------------------
-----d7h10p7------d7h10p7------u10P7------d7h10p7-----u10p7------d7-----------------7---
-d9-------------d9--------------------------u9-------------------------u9------u10p9p7p9------7-
https://www.youtube.com/watch?v=DxA4WgI ... .be&t=2m8s
wjamflan
Re: Panama Solo Fast Lick. Suggestions?
Post by wjamflan » Sat Feb 06, 2016 7:09 am
Maybe this will help:
------------------H----P------------H----P-------------P----P-----------H----P------------P-----------------P----P---------------------
E------------------------------------------------7------------------------------------7-----------------------------------------------------
B----------7---7---10---7-------7---10---7--------10---7---0-------7---10---7-------10---7-------7----------------------7-----------
G---9------------------------9-------------------------------------9-------------------------------9-------10---9---7---9--------7-------
D--------------------------------------------------------------------------------------------------------------------------------------------
A--------------------------------------------------------------------------------------------------------------------------------------------
E--------------------------------------------------------------------------------------------------------------------------------------------
-----D-----D---U------------U---D--------------D---U------------U---D-------------D---U-------U---D---U-------------D---D---U-----
Slowed Down: http://www.mediafire.com/?1pfpccs49px646p
Good luck!
jculb69
Post by jculb69 » Sat Feb 06, 2016 3:51 pm
Thanks! I'll give it a try. I'd missed that double 7-7 near the beginning, but you can hear it when slowed down.
Santino
Post by Santino » Sat Feb 13, 2016 9:25 am
I know he probably picks it the way the tab says. However I have seen him tap it at least a couple times. It's like the last lick in the solo to Romeo Delight. Every YT clip I've seen he taps it. I was thinking about this same thing last week and started looking into it. I got caught up on the RD lick and didn't make it to the Panama one. Even though it's Panama that got me started thinking. Unfortunately since he started playing RD in 2007 the doesn't play that lick in the solo. So we've lost that oppurtunity to see how he does it. Maybe he tapped both in the studio? He does play things differently live sometimes. Panama is a tough lick to pick at speed. I fake my way through by almost sweep picking e to b string into the pull off and hammering onto the g string.
garbeaj
Post by garbeaj » Sat Mar 12, 2016 10:45 pm
wjamflan has this TAB'ed correctly. No need to look any further to see exactly how Eddie played this part on the 1984 album. There is no need to see anything else other than what wjamflan has posted above. It is 100%, absolutely, positively correct.
If it is still hazy, check out my thread here, which I completely got from wjamflan:
http://forum.metroamp.com/viewtopic.php?f=49&t=44067
Santino
Post by Santino » Thu Mar 17, 2016 1:42 pm
garbeaj wrote:wjamflan has this TAB'ed correctly. No need to look any further to see exactly how Eddie played this part on the 1984 album. There is no need to see anything else other than what wjamflan has posted above. It is 100%, absolutely, positively correct.
Yep. I get it now. Thanks!
jculb69
Post by jculb69 » Tue Mar 22, 2016 5:10 pm
Interesting that the high e string is played with a downstroke. I've been playing it with an upstroke. I'll try it when I get home I've tried slowing down videos to his picking on this, but they are either too fuzzy or too fast. Thanks for the info and thread below!!!
garbeaj
Post by garbeaj » Tue Mar 22, 2016 11:04 pm
jculb69 wrote:Interesting that the high e string is played with a downstroke. I've been playing it with an upstroke. I'll try it when I get home I've tried slowing down videos to his picking on this, but they are either too fuzzy or too fast. Thanks for the info and thread below!!!
You are welcome...no need to struggle with videos or any other transcriptions, wjamflan has done all the work for you! Just play it as he has it TAB'ed and you will be playing it exactly like Eddie is playing it on the record!
