How do I get rid of this noise other than making a more tidy amp
Here are two videos which should help you understand my issue.
alright, I'll clean things up and report back soon...white noise wrote:Without tidying up the amp wiring I don't see that sound going away.
Watch the dropbox video. I get massive hiss when trying to implement Michael R/T 's one wire mod. Other than the hiss everything else is working great...rgorke wrote:did I read it right that with no cable in the inputs, there is noise? There should be no noise or maybe some hiss with nothing plugged into the amp.
I had a bad input jack that didn't close all the way. Make sure your jacks are wire correctly. Also, check your voltage on the plate resistors and make sure all your components are the right value. Some folks have had miss marked components or read them wrong.
Finally, make sure the tube socket is wired neatly and there are no unintentional connections between tabs. Your socket may also be bad or damaged.
Does the NFB make a difference? Does the sound change turning the presence control?
Hiss is normal. Buzz is not normal. Hiss is shot noise and with that much gain on tap, you are hearing the sound of the stream of electrons boiling off the filament and slamming into the anode.metalhead3ecr wrote:I get massive hiss when trying to implement Michael R/T 's one wire mod. Other than the hiss everything else is working great...
