Duncan Custom 78 regular or trembucker
procuring my bridge pickup for my red-black-white Frankenstrat. Although the humbucker is angled, should I use the normal pole spaced humbucker or the trembucker spacing?
- markstullkc
Re: Duncan Custom 78 regular or trembucker
Normal spaced
The reason you angle it is so the stings line up on the pole pieces. Low E over the slug, high E over the screw.
Byproduct is killer low end.
If you got trembucker, no reason to angle it.
- garbeaj
Assuming you weren't building a Frankenstein replica, at least on a visual level. Would you be sacrificing tone by getting a trembucker and not slanting it?
It also seems to me that the pickup is not angled as sharply on the black and white version of the Frankenstein with the black pickguard as it is in the famous red-black and white version with no pickguard...am I wrong about that?
reg spaced, for two reasons first if you are going to angle it it will line up better and reason two is eddie used a reg spaced and there IS a diff in sound between the two,i own both
- garbeaj
Clips of the difference between the two?...I mean the difference between a trembucker mounted straight and a Gibson spaced pickup mounted slanted. I know it is apples and oranges, but Ed did just end up putting his pickups straight from the 5150 guitar onwards...Marshall SL12301 wrote:reg spaced, for two reasons first if you are going to angle it it will line up better and reason two is eddie used a reg spaced and there IS a diff in sound between the two,i own both
no i was stating that the reg spaced pus and the tremspaced sound different from each other. the trem spaced pu's are wound hotter for instance i have a JB reg and TB4JB and the TB4 is 17.7K and the reg JB is only 16.2Kgarbeaj wrote:Clips of the difference between the two?...I mean the difference between a trembucker mounted straight and a Gibson spaced pickup mounted slanted. I know it is apples and oranges, but Ed did just end up putting his pickups straight from the 5150 guitar onwards...Marshall SL12301 wrote:reg spaced, for two reasons first if you are going to angle it it will line up better and reason two is eddie used a reg spaced and there IS a diff in sound between the two,i own both
Sorry to sound like an ass here but dude, if you're doing a VH guitar, do what Ed did and use what Ed used. After all, you're into that sound for a reason, right? Normal spacing it should be.mdc1 wrote:procuring my bridge pickup for my red-black-white Frankenstrat. Although the humbucker is angled, should I use the normal pole spaced humbucker or the trembucker spacing?
Cheers to the ears.
- garbeaj
WTF?! I wonder why the trembucker version is hotter? Maybe it was just a variance in that particular pickup...Marshall SL12301 wrote:no i was stating that the reg spaced pus and the tremspaced sound different from each other. the trem spaced pu's are wound hotter for instance i have a JB reg and TB4JB and the TB4 is 17.7K and the reg JB is only 16.2Kgarbeaj wrote:Clips of the difference between the two?...I mean the difference between a trembucker mounted straight and a Gibson spaced pickup mounted slanted. I know it is apples and oranges, but Ed did just end up putting his pickups straight from the 5150 guitar onwards...Marshall SL12301 wrote:reg spaced, for two reasons first if you are going to angle it it will line up better and reason two is eddie used a reg spaced and there IS a diff in sound between the two,i own both
But I seem to recall that when asked why he stopped slanting the pickup (from the 5150 guitar onwards) Ed said "I guess I just stopped caring"...I guess it depends on which guitar and tone you are trying to replicate...
Trembuckers are hotter due to the larger bobbins they have to accommadate the wider spacing of the poles
- garbeaj
Aha! So a trembucker version of an SD '59 would be like a P.A.F. but very slightly hotter?Marshall SL12301 wrote:Trembuckers are hotter due to the larger bobbins they have to accommadate the wider spacing of the poles
That is correct!
That is correct!
