MCP 2nd degree black belt,VH I tone in a pickup!
vanhalen5150
Re: MCP 2nd degree black belt,VH I tone in a pickup!
Post by vanhalen5150 » Wed Sep 12, 2012 11:29 am
I have a Darkburst and a MC BB2. I can't tell the difference between them. Both sound great.
If you listen to the "stratplexi" clip, I believe it was Mark playing in this clip.
http://www.wcrguitar.com/darkburst_clips.html" onclick="window.open(this.href);return false;
Star*Guitar
Post by Star*Guitar » Wed Sep 12, 2012 12:28 pm
There is a real difference. Tightness in the low end. Gain without after note artifact or clutter. Very sweet harmonically. I have 2 second degree blackbelts. I have had them for quite some time since I heard Stan's clips years ago. I am about to buy a third of my Wolfgang.
Star*Guitar
mightymike
Post by mightymike » Wed Sep 12, 2012 7:15 pm
vanhalen5150 wrote:I have a Darkburst and a MC BB2. I can't tell the difference between them. Both sound great.
Couldn't tell the difference. I wouldn't have expected that answer. :shock:
vanhalen5150
Post by vanhalen5150 » Wed Sep 12, 2012 7:49 pm
They are very similar.
Marshall SL12301
Post by Marshall SL12301 » Wed Sep 12, 2012 9:23 pm
yeah when you get into comparing the same spec models 9K,alncio 5 blah blah blah they will sound very similar but being that the Darkburst is a alnico II i hear a difference from the MCP 2nd BB. if you were to put a II in the MCP they are probably the same thing :lol:
mightymike
Post by mightymike » Wed Sep 12, 2012 9:30 pm
I prefer the lower imp pickup like this for VH1 and then juice up the signal with an EP3 and EQ for a very dynamic and open tone. I like the drive of a SH5/ JB for the for VH2/WACF.
mightymike
Post by mightymike » Wed Sep 12, 2012 9:32 pm
Marshall SL12301 wrote:yeah when you get into comparing the same spec models 9K,alncio 5 blah blah blah they will sound very similar but being that the Darkburst is a alnico II i hear a difference from the MCP 2nd BB. if you were to put a II in the MCP they are probably the same thing :lol:
Unless he changed the Magnet. I've ordered them with different magnets.
Post by Tone Slinger » Wed Sep 12, 2012 10:34 pm
I got a '06 Duncan 'Custom Custom' that absolutly KILLS. I'm not sure of the consistancy of pu's, though I'm assuming they are of VERY tight tolerances, especially the BIG companies (Seymour & Dimarzio).
I have been listening to the bootlegs alot recently. If Ed got his FIRST Seymour pu in '77 (like IF he used a Duncan 'rewind' on the first VH album, a SH-5 'Custom'), then WHY did he choose yet ANOTHER Duncan pu type later (the '78 tour). Seems to me that Ed used a Mighty Mite 'Screamer' (DSD clone) up to and including the '77/'78 New Years/Eve Whiskey gig. The '78 stuff is slightly warmer with less gain, like *possibly* a a2 awg 42 wind at 9k ( Duncan '78) or even a JB (the awg 44 wire wound to 16 k slightly softens or WARMS up an A5 magnet).
Regardless, of all else, in my personall exp. ( I run a 12xxx Mod5 spec amp through a 4/12 loaded with 6402 coned green backs) The Duncan 'Custom Custom' is, BY FAR, the most VH1 sounding pu I've ever heard, though, technically speaking, it isnt what he used.
JimiJames
Post by JimiJames » Wed Sep 12, 2012 11:04 pm
Not to go too much off topic, but Man ! That MCP Woodward Alnico III Single Coil is one of the better or best pickup in a Marshallesque amp for the neck position I've heard in a long while.
Definitely ordering one of those no doubt !
vanhalen5150
Post by vanhalen5150 » Thu Sep 13, 2012 7:17 am
Tone Slinger wrote:I got a '06 Duncan 'Custom Custom' that absolutly KILLS. I'm not sure of the consistancy of pu's, though I'm assuming they are of VERY tight tolerances, especially the BIG companies (Seymour & Dimarzio).
I got one of those Duncan CC's as well. Havent had time to put it in anything but it does sound promising. I found it on ebay for $65.00. Still in original packaging. Not sure of the year but it has a black/green bobbin combo.
rgorke
Post by rgorke » Thu Sep 13, 2012 11:10 am
mightymike wrote:I prefer the lower imp pickup like this for VH1 and then juice up the signal with an EP3 and EQ for a very dynamic and open tone. I like the drive of a SH5/ JB for the for VH2/WACF.
Mike,
You have hit the nail on the head for what I am discovering with my tone search. The lower PAF-ish pickups with a bit of push from an MXR EQ is seems to getting the best tone for me right now. I can put the pickup closer to the strings and not get an over whelming amount of distortion or gain that makes things mushy. There seems to be a significant amount of clarity with the lower output pickup.
With a higher output DSD or MM1300 or so, I need to put the pickup much further away from the strings in order to achieve the clarity of the PAF.
Roger
Leotis
Post by Leotis » Thu Sep 13, 2012 5:45 pm
Soooo... you MCP 2nd Deg BB users, I just got one myself and I'm getting conflicting info regarding the wiring. Is black hot or green? I know the red/white get taped together and back. :what:
mightymike
Post by mightymike » Thu Sep 13, 2012 11:13 pm
Mike,
Roger
Agreed, and I also like puting the EP3 on the Jumper between the channels and make channel2 extremely wet to get the color on channel 2 without it effecting the bite and tightness on the bottom end of channel one. But put the eq before channel1, but I might ony turn up channel 2 to 2 or so. By setting it up this way the channel 2 volume just becomes the delay volume control froma totaly wet channel. Open dynamic tone, and it really shines through this way with these 8 to 9k assymetrical wind pups.
rgorke
Post by rgorke » Fri Sep 14, 2012 10:00 am
mightymike wrote:
Mike,
Roger
Yeah, but there is an extra something that you get running the EQ into the EP3. Lots of options!!!!
vanhalen5150
Post by vanhalen5150 » Fri Sep 14, 2012 10:40 am
Leotis wrote:Soooo... you MCP 2nd Deg BB users, I just got one myself and I'm getting conflicting info regarding the wiring. Is black hot or green? I know the red/white get taped together and back. :what:
Usuall black is hot, and green is ground. But sometimes (black) its a ground. Just use a multi tester.
I always get my PU's with the old braided 2 wire, if I can. I don't need no split coil taped dodads hanging out in the cavity..... :lol:
