no secrets here...You know I'll spill the beans
So the Phase 90 plug in - I just found it on the KVR audio site, like just sat. - I'm always trying out new plug ins to learn more about home recording and what-not ....some great stuff out there...just have to sniff it out..
Go to the kvr audio plugin data base ( KVR audio .com ) - type in MXR Phase 90 - about 12 different phase units will pop up
go to the one from Smart-electronix - it isn't endorsed by MXR but, it is the only one I've found the tries to replicate it(MXR Phase 90) it says so in the description ..so you know you found the correct one.It also says known not to work ,,,ahhh don't buy it for a minute..downloads quick with no issues..sounds pretty darn close once dialed in and I'm not even quite there yet.
it has 3 settings (I know the MXR has only one ) - I'm still messing with it but, some killer potential using it, I can tell you that .....I set the first 2 sliders just above minimum , it is still more than subtle ....sounds cool.but you dial it down further and will be more vintage script-like.
Later on...I really want to get that in-your -face Atomic Punk phase thing going and think this plug in can do it.
or I think I will sniff around for MXR type Flanger Plugin and see If can drum up a cool mix of the 2 like Ed used to....
just for a cool effect on breaks and stuff.
