Opinion of Marshall 1959 Reissue?
Re: Opinion of Marshall 1959 Reissue?
Once you have a genuine 1959 type, 4 hole, two stage plexi circuit, you are on the right path. And if it's hand wired, you'll be off and running in no time as component changes and experiments are very easy. Variacs, changing tubes and setting bias will all fall into place. Swapping transformer too. Lots of people here to help, myself included. I don't frequent here as much as I used to but am circling back more often now.
I guess the only major thing I'd change on these are the output transformer. (A few caps are minor issue)
