Just about to embark on the adventure of my first amp build! I will be building a '68 era 50 Watt Plexi, from the very excellent, and comprehensive Metroamp 50 Watt build instructions, using the majority of the parts from Valvestorm.
However, I am in a 'state of flux', as to the timing of the installation of the LarMar PPIMV Mod.
Common sense would suggest that the mod should be installed during the build (why fit 2 x 220K Resistors, and route two wires to the Output Tube Socket Grids, only to remove them again later!), or would it be preferable to complete the standard build, and go through all the testing procedures to ensure the amp is working correctly first, and then install the Mod?
I guess what I am trying to say is: Logic would suggest that the test readings should be the same with the Dual 250K Pot 'dimed', as they would be with the amp in standard Non-MV spec, but would that actually be the case? Would the introduction of the mod during the build, cause some unreliable test readings at the end?
Thanks for reading!
Webby
