mounting clamps and ARS caps
Hi guys !
Please tell me , How to mount securely the ARS 50/50 caps into mounting clamps? ARS caps seem to be a bit thinner. What would you recommend ? I have these kind of typical mounting clamps available at velvestorm store (Medium Can Clamp
1 3/8"). Is it possible to use some tape inside the clamp like window isolation tape ? THNX
Re: mounting clamps and ARS caps
thnx Neil ! but the rubber inner tubing will isolate the heat, or it doesnt matter ? thnx . any other tips ?
- demonufo
Ferrous clamps won't really wick the heat anyway. Not a concern. It's an old time practice to use rubber strips in capacitor clamps where the size varies. I have even seen a few of John Farlowe's Exposure amplifiers leave the factory like it when Rifa changed it's capacitor specs.
So I like purple, okay!!!!!!
I have put these in many amps from 69-75 and they fit fine for me.
The UK ARS must be skinnier than the US onesJoshabr1 wrote:I have put these in many amps from 69-75 and they fit fine for me.
I had to put a wrap or two of electrical tape on mine but I like Neikeel's suggestion better. Gotta go find some old inner tubes now!
Really good filter caps regaurdless.
