Metro-Friedman "plexi" ready to go!
Replica amps built by George Metropoulos himself. Visit PlexiReplicas.com.
Post by VelvetGeorge » Mon Oct 10, 2011 1:05 pm
After a few final tweaks and some critical listening the Metro-Friedman plexi collaboration amp is available to order.
The jist of the amp is:
aggressive plexi that begs to be dimed and retains detail at this setting
voiced for "brown" tones but also covers all the tones from '68 era and up Superleads
includes a 3 way power switch for OFF / ON NORMAL / ON VARIAC
the variac setting simply drops all the voltages in the amp, like an external variac set to 90V AC
6CA7 output tubes
1968 era specs
Price is $3,200 USD
The amps are assembled here at Metro. I should be able to start shipping in 3-4 weeks. Contact me for more info and ordering: sales@metroamp.com
In the LA area you can stop in Tone Merchants in North Hollywood for a demo.
Re: Metro-Friedman "plexi" ready to go!
Post by NY Chief » Mon Oct 10, 2011 2:45 pm
Another home run, George!! :thumbsup: :worthy: :champ: :rock: :toast:
dmcguitar
Post by dmcguitar » Mon Oct 10, 2011 8:06 pm
Sounds Awesome!
vids / sounds clips?
www.atomicfury.com
that's my band, Im the sole guitarist. Go ahead listen and tell me what you think.. of the band. or me.
-5150II
-custom (I made) 2x12 cab
-custom (I made) strat guitar
-Wayne strat
Post by VelvetGeorge » Mon Oct 10, 2011 9:01 pm
Hope to have some clips from the ap show soon. My recorder was packed with all the gear that shipped back here on a pallet, due to arrive tomorrow.
Thanks Mike!
bwgintegra
Post by bwgintegra » Mon Oct 10, 2011 11:05 pm
Here is a short clip I took of the Metro-Friedman Amp from the LA Amp Show
[youtube]http://www.youtube.com/watch?v=PakrGX_5kW0[/youtube]
OnTheFritz
Post by OnTheFritz » Mon Oct 10, 2011 11:25 pm
Wow, sounds killer! :drool:
OdgeUK
Post by OdgeUK » Fri Dec 30, 2011 4:35 am
This seems to be a very similar amp to the Suhr SL68. And I beleive both are around the same cost to buy. What are the main differences?
73 JMP 1987 w/LarMar
78 JMP 1987
79 2104
Peavey JSX 120
Marshall 1936 G12-65
Post by Roe » Fri Dec 30, 2011 8:48 am
Is it only available with 120v or do you have 230v as well? I guess you need more primaries because of the variac thing
Post by VelvetGeorge » Fri Dec 30, 2011 11:20 am
It is available wired for 230V operation, including the variac function.
Big Mike
Post by Big Mike » Sat Dec 31, 2011 12:33 am
OdgeUK wrote:This seems to be a very similar amp to the Suhr SL68. And I beleive both are around the same cost to buy. What are the main differences?
It's George Built!!!
:rock: :rock: :rock:
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
cole
Post by cole » Wed Jan 04, 2012 10:55 am
George,
This may be a redundant question but...if we own a Metropoulos built 12 series plexi replica and we use the recommended 6CA7 outputs and drop the input voltage the amp sees to 90 volts can we expect to get the same results tonally or is there more to it (i.e.: component changes)?
The UA (Ultimate Attenuator) I am using has a 90v AC service outlet. I have used this with your 12 Series amp (with the virtual variac switch on the high (full) voltage switch setting) and it does wonders to the tone and feel.
So if I happen to grab a quad of 6CA7's (EH brand) in replace the EL34's, am I then all the way there to what a Metro-Friedman amp would offer?
Cheers!
Les Paul Classic, Les Paul Standard Faded, Fender American Strat
Jackson Custom Shop Strat s/n 1226
JMP 2203, JCM 800 2205, Metro JTM 45
Metropoulos '68 12 Series s/n 12026
Marshall 1960 A/B 4 X 12's
Post by VelvetGeorge » Wed Jan 04, 2012 2:23 pm
That would be close. I'm giving away the whole formula, but the negative feedback and some values and types of components are different.
OdgeUK
Post by OdgeUK » Thu Jan 05, 2012 3:57 am
I was assuming this was probably the "Friedman Spec" that's been posted here, with internal Variac option. From what I can gather, both Friedman and Suhr have worked on Ed's amp and this looks like both have decided recently to put out their take on that?
78 JMP 1987
79 2104
Peavey JSX 120
Post by Roe » Thu Jan 05, 2012 4:24 am
VelvetGeorge wrote:That would be close. I'm giving away the whole formula, but the negative feedback and some values and types of components are different.
No, you're fine-tuning the whole amp. people won't get the same result by just changing some values
dnatronic
Post by dnatronic » Thu Jan 12, 2012 9:07 pm
Hey George, if we already own one of your 68 plexis, can we send it in and have you mod it to these specs? Also, what 6CA7 tubes are you using?
