I went to turn on my GPM the other day and it was dead so I checked and the fuse was blown, I replaced the fuse and the indictor light came on but no sound. What's is the issue?
-Chris
GPM45..light is on but no sound
- CALI
- Flames1950
Re: GPM45..light is on but no sound
Did you check both the internal and external fuses, or only the external one? I'd bet the fuse inside for the high voltage line is blown too -- likely time for new output tubes as well if that fuse is blown.
- CALI
Flames1950 wrote:Did you check both the internal and external fuses, or only the external one? I'd bet the fuse inside for the high voltage line is blown too -- likely time for new output tubes as well if that fuse is blown.
Thanks! I didn't do that ...I'll check right now!
Much appreciated!
-Chris
