A 12-bit analog-to-digital converter, the working voltage is 5V, the working frequency is 1MHz, how to calculate the sampling rate, why some sampling rate units are Hz, and some are sp/s, s/s, does anyone know what it means? , can you tell me how to calculate?
Introduction of ADC: https://www.utmel.com/blog/categories/i ... ling-rates
How to calculate sample rate in ADC
- Freebird
Re: How to calculate sample rate in ADC
Hi Roseljr
One has to know, that 1 Hz (Hertz) is the same as 1 sp/s (sample per second) and also is equal as 1 s/s (sample per second).
And that a sample rate means how many time a signal will be sampled each second.
I hope that helps you.
Best regards
Daniel
Best regards
Daniel
Indic Input is completely free to use. It comes with extensive help documentation that explains everything there is to know about Indic Input. Install Indic Keyboard For PC
