Sorry about the length of this query, but need to explain my problem fully to hopefully get a diagnosis from all you experts out there!
Back in 2013, I built a ‘69 era Plexi from the Metroamps PDF Instructions, and fitted a LAR MAR PPIMV to it. It sounded pretty awesome from day one, but it’s always had a kind of distant ‘background’ level high pitched squeal when gain is at or near max level. Just recently, I bit the bullet and purchased a Tone King Ironman II 100 Watt Power Attenuator, which allows me to play my amp maxed out at bedroom volumes. It does sound awesome while you’re playing the guitar, but as soon as you stop playing, the high pitched squeal is very noticeable. It’s not pickup squeal because I have tried my Les Paul at high output levels with other amps, and there is no problem. If I touch the metal Attenuator casing however, the squealing gets really loud! This doesn't happen with other amps, so I guess the fault must be with my amp. Some kind of screening issue?
Driving me nuts, so any suggestions would be greatly appreciated! TIA
