I have gotten some tips from this forum, but I ran into a wall.
I got the bug of building a JCM 800 clone.
Things were going fine, I thought until I flipped the switches.
I cannot find the high voltage on the amp. It gets up to 53 VDC. I have a feeling that the power section got wired wrong.
This is the PT:
http://www.classictone.net/40-18095.pdf
This is the layout:
https://tubeamplifierparts.com/layouts/ ... layout.pdf
This is the diagram:
https://goo.gl/images/DTCFNT
I wired a red and a red/yellow to the standby switch as shown in the layout. I put shrink tubing on the other red. I get 420 VAC on the standby switch, top 2 terminals. However, I can’t seem to find DC voltage greater than 53 Volts.
Any help is appreciated!
Thank you!
Gabriel
