Spanky jmp faceplate instalation?
Am I supposed to use tape for spankys plate? It says don't peel off backing but the metro plate you peel off the tape. Wht should I use to secure the faceplate? Thanks
Re: Spanky jmp faceplate instalation?
Use double-sided scotch tape or nothing at all. Do not use glue or other adhesives. The front panel may not need anything... the controls will hold it in place.
- Gunny Highway
- Gunny Highway
