Is it possible to build a 68 plexi Metro 12xxx?
Hi,
I want to build a Metro 12xxx, where is the manual? i found this topics and a good METROAMP 100 WATT PLEXI KIT PDF manual, but i did not found the same PDF for the metro 12xxx. I really want to build the 68 era.
Is it possible to build a 12xxx with this informations below?
67-68 Superlead full amp layout
http://forum.metroamp.com/viewtopic.php?f=26&t=11948
100 Watt Kit Boards Lead and Bass
http://forum.metroamp.com/download/file.php?id=4857
Board component names
http://forum.metroamp.com/viewtopic.php?f=26&t=15719
Build checklist for 12Xxxx Series
http://valvestorm.com/12xxx%20Series
12 SERIES PARTS LIST
http://forum.metroamp.com/viewtopic.php?f=29&t=9972
METROAMP 100 WATT PLEXI KIT ( I think this is not for 68 amp)
http://www.metroamp.com/downloads/100_W ... MP_KIT.pdf
thanks
thanks
Re: Is it possible to build a 68 plexi Metro 12xxx?
Of course it is possible to build a 12 series (68 spec) Metroamp Superlead.
- if you can read a schematic and undestand the build layouts and keep posting pics on the 12 series build section
- if you are a beginner I suggest you make sure your wires are stock Marshall colours, that the wires for turrets are post 69 style with them pushed up through the holes in the board and wrapped around the turret, wire your bus wire above the board. You can out them under the board like early amps but helping out with wiring mistakes if you do it that way is really difficult over the net.
- you can use other transformers if you want, but again non-stock colours and arrangements are really hard to help with, I suggest, Metro, Marstran or from the Dark Side of 'he who must not be named'
- Strat78
All those links are definitely must haves...It looks like you did your research already,....and great advise from Neil. Start a thread down in the 12 Series Journal section and post pics of your progress. Also, go through some of those threads for examples of great wire dress. Night Owl made a nice pictorial how to for the 12xxx:
http://forum.metroamp.com/viewtopic.php?f=44&t=27851
Here is MightyMikes GIF showing the super bass layout:
http://www.mediafire.com/view/i4z59v958 ... mation.gif
Once the amp is done there will be plenty of guys who can help with fine tuning the tone.
Yes, i´m beginner. I will buy all the parts. Any sugests? i see that have some options on valvestorm. thanksneikeel wrote:Of course it is possible to build a 12 series (68 spec) Metroamp Superlead.
the most dificult part is where do i solder all the transformers wires.. ? people here could help me? even a beginner?
thanks
i saw NIght Owl topic, it´s great.Strat78 wrote:All those links are definitely must haves...It looks like you did your research already,....and great advise from Neil. Start a thread down in the 12 Series Journal section and post pics of your progress. Also, go through some of those threads for examples of great wire dress. Night Owl made a nice pictorial how to for the 12xxx:
The PDF for 100W kit is´s fantastic, i wish had some for the 68 era. I need help step by step even for a filaments wires, socket connections, everything.
Do you think a beginner can build a 68?
Is it possible to change the socket amphenol to a cheaper? $17 each is very expensive,
thanks
I look the picture 68 plexi chassi from metro website, it´s very clean and beautiful point to point build. Very clean.
- Strat78
Ha ha, I made a large printout of George's 68 build chassis pic and have it on my shop wall, it's art! MightyMikes pdf is pretty much what a 12series looks like except for about four little caps and a resistor. Just compare it to Billy Batz pdf that you linked to. Start familiarizing yourself with the values, a good place to start is the simple differences between a bass and a lead circuits. But the best way to do this is just to get started and take it slowly. Oh, and yes, just go with the Micalex sockets. Robert at ValveStorm has a batch of 12series chassis that fit those just fine, just specify. You don't need the tube retainers and just go with newer production parts for now. Check out this thread that George posted for best location of carbon comp resistors and use carbon film for the rest:http://forum.metroamp.com/viewtopic.php?f=26&t=16794Goonies wrote:I look the picture 68 plexi chassi from metro website, it´s very clean and beautiful point to point build. Very clean.
If this project is too much to tackle, grab an old ValveJunior off eBay and grab a plexi conversion kit and go at it. You'll learn allot. Still, you can easily do a 68 if you take your time.
- Supporting Advertiser
Collated all of the pics and instructions from Night Owl here:
http://www.mediafire.com/download/uj79s ... ghtOwl.zip
AND
I just got a new batch of the newer version of the 12series chassis that can use the less expensive Belton sockets:
Also, be sure to get the Double-D fuseholders for the new chassis.
AND
- Strat78
Don't know if the OP is still with us, but for anybody ells who is interested, check out this vid from Germino, really good struff. Thanks Ben for posting this way back:
https://www.youtube.com/watch?v=zr08UMqa1ww
Strat78,
This is a very good video from Germino. Thanks!
these construction details are very important for beginners.
a short and simple video. Should have more videos like this explaining the basics of a building. This greatly encourages the assembly itself.
What and make it that easy for everybodyGoonies wrote: Should have more videos like this explaining the basics of a building. This greatly encourages the assembly itself.
i think i saw other video linked with it, the video at this url it´s very short and not explanatory.
