which is a Safer Load
bobtec
Post by bobtec » Sun Mar 16, 2014 8:03 am
Which is the safest cab to use..I have a 16ohm cab and a 4 ohm cab... I have a 8ohm reactive load(power Tool) and the manual said I can run it down to 2 ohms...If I hook my slp100w up at 8 ohms to the power tool at 8 ohms, what cab can I use that wont hurt the amp or reactive load,or do I need a 3rd cab at 8 ohms :what:
cruisemates
Re: which is a Safer Load
Post by cruisemates » Thu Sep 11, 2014 2:21 pm
It is my understanding that it is critical to have the right ohmage on your cabinet with an attenuator. Furthermore, you do not want to mix speakers of different ohmage on your load (for example, putting on the 4 and the 16-ohm to get a 5.4 ohm load. Because of the difference in efficiency in the speakers you can damage the amp.
Remember that ohmage is a constantly changing figure - depending on frequency, etc. For the circuit to be "happy" it has to remain in balance electronically.
stef
Post by stef » Thu Sep 11, 2014 6:38 pm
amp - 8ohm
attenuator - 8ohm
cab - 16ohm
bobtec
Post by bobtec » Sat Oct 04, 2014 3:46 pm
On the reactive load attenuator I have(Power Tool) it said it can go down to 2 ohm,so why go up to 16ohms In the manual it says Amp at 8 ohm load I only have a 16 and a 4 ohm cab Fender Cabs... in a 100w.Plexi ri what is harder on the OT 16 or 4 ohms
FL6
Post by FL6 » Sat Oct 04, 2014 4:43 pm
stef wrote:amp - 8ohm
attenuator - 8ohm
cab - 16ohm
That's what I have. It's ok to use this config?
