voltage specs for ceriatone 50 watt yeti
Turd Ferguson
Post by Turd Ferguson » Tue Dec 31, 2013 6:17 pm
Can someone give me the right specs for all voltage check for Ceriatone 50 watt Yeti new amp build. also should I check the bias at pin 5 or with bias test on back of amp because I get something different when I check each? I tried checking at bias test on back of amp and it is reading in + mv and not - mv is that right? just need to check to see if everything is within specs but cant find anything on this amp.
Turd
Turd Ferguson
Re: voltage specs for ceriatone 50 watt yeti
Post by Turd Ferguson » Tue Dec 31, 2013 6:23 pm
Oh and I attached the layout of the amp
wyatt
Post by wyatt » Tue Dec 31, 2013 8:24 pm
Do you have this?
http://ceriatone.com/voltage/VoltageChart.xls" onclick="window.open(this.href);return false;
Separate spreadsheets for each amp, the Yeti 50 is one of the first tabs displayed.
I tried to enter it in this post as a table, but this forum apparently doesn't recognize that code.
Turd Ferguson
Post by Turd Ferguson » Tue Dec 31, 2013 8:45 pm
Thanks Wyatt :D
wyatt
Post by wyatt » Wed Jan 01, 2014 1:19 am
I should have added the caveat that these are with Ceriatone's PT at Maylasian voltage. If your PT has a different HT voltage or spec'ed to a different load then you might see some proportional variances. If the HT is higher then expect all the plate voltages to be higher, etc.
