Blue glow
Ukko75
Blue glow
Post by Ukko75 » Fri May 25, 2012 5:21 am
Hi!
I know it is normal that the powertubes glows blue. But is that normal that V4 glows blue and V5 not, when guitar is played. V5 starts glowing blue and V4 not when guitar is not played?
The amp is Plexi 50W.
All voltages are normal and bias is correct. Sound is normal too.
54strat
Re: Blue glow
Post by 54strat » Fri May 25, 2012 1:00 pm
Blue-ish glow is nothing to worry about.
73 Marshall 1987
87 Fender Stratocaster
toner
Re: Blue glow
Post by toner » Fri May 25, 2012 6:52 pm
Not sure how accurate this is but:
http://thetubestore.com/blueglow.html" onclick="window.open(this.href);return false;
It is common for the V4 side (or V4/V5 in a 100w) to receive a stronger input signal due to how the PI is not perfectly balanced. Honestly, I'm not sure about the technical details of how this relates to "blue glow" but that side usually works harder in a Marshall. That's why it is usually best to put "colder-biased" tubes on that side if the two halves are not well matched. If voltages and bias are okay, don't worry about it! :wink:
Ukko75
Re: Blue glow
Post by Ukko75 » Sat May 26, 2012 2:44 am
Thanks you guys wery much for releafing information!
