Voltage Regulator Question
Curious if anyone has used a voltage regulator on their amps? The voltage at my house is not steady and can range from 113- 121 volts. I just bought a Furman ar 117 Voltage Regulator and have read good/bad about using them. Any advise would be helpful. Thanks.
- Structo
Re: Voltage Regulator Question
Yes if you have bad fluctuations a good conditioner/regulator is a good thing.
They are expensive for the good ones.
Not sure of the range they operate in but it should make the amp work more consistently.
Especially in the over voltage situations.
The power tranny on an amp simply takes what it gets and puts it to the secondary so a 10% rise in the wall voltage can translate to a higher than desireable voltage on the heaters or B+.
Tom
Don't let that smoke out!
- novosibir
... and changes the bias based output tube dissipation!Structo wrote:... so a 10% rise in the wall voltage can translate to a higher than desireable voltage on the heaters or B+.
Adjust your output tubes to 70% of max. plate dissipation at a wall voltage of 113V
check it again at a wall voltage rise to 121V
and you'd have someting about 75...78% of max. plate dissipation
Means, that you have to take 'this' into account, when you bias at low wall voltage periods!
Larry
- Structo
If you gig a lot (especially if you ever gig in foreign countries), it's invaluable. I had a complete meltdown at a gig a while back between my amp and rack due to bad power -- I went from normal volumes to a whisper in the middle of songs, and I couldn't get my racks to change channels -- so I bought a Furman P-1800 AR and haven't had an issue since.
