output decoupling caps
jester
Post by jester » Sun May 24, 2009 10:42 am
Does the voltage rating matter on the decoupling DC blocking caps like say .022@600v or can it be .22 @50v?
Maverick
Sparky
Re: output decoupling caps
Post by Sparky » Sun May 24, 2009 8:25 pm
If you're referring to the caps between gain stages, yes, the voltage does matter. Since the grid of the next tube stays close to ground and the plate of the previous stage can vary from ~0V to the supply voltage for that stage, you want the cap rated for at least the supply voltage plus a safety margin - usually 400V or greater.
