Voltage IS potential. Voltage is the unit of measurement for potential. A voltage (i.e. "charge differential" or "potential") must exist between two points (i.e. the two terminals of your filter cap) in order for electrons to potentially flow through a circuit connected between said two points (i.e. again your filter caps two terminals). No charge differential = no voltage = no potential for electrons to flow.noworrybeefcurry wrote:So the filter caps in your power section dont specifically provide a voltage to your plate, but they are more a source of potential for current to flow, is that correct?
But voltage is relative to something. In the case of the filter cap, the positive voltage is relative to its negative side. You can't just connect one meter probe to the positive terminal only and see a voltage. The other meter lead has to be connected to the reference that said voltage is relative to in order to complete the circuit and see the voltage.
Kinda like when you measure something with a measuring tape...your measurement is relative to wherever "zero" on your measuring tape is. Same thing with electronics. Picture your multimeter as your "electrical measuring tape"...the "COM" meter lead (i.e. the black one) would be your electrical measuring tape's "zero".
Because capacitors are charged/discharged via alternating charges, whether they're "alternating DC" (i.e. DC that alternates above and below a fixed voltage) or pure AC (current/voltage that alternates above and below zero).noworrybeefcurry wrote: I do understand the concept of gain within a tube, but their is another thing that has me slightly confused. How is it that the coupling caps will pass the alternating DC? In the end it is still DC, so is it just that the cap itself does not have a chance to fully charge?
-Thank You
The key is to have them be alternating charges. With a static DC charge, the capacitor only draws current during it's charge up. Once charged up, no more current flows through RL. No current flow through RL = no voltage drop across RL.
But as soon as the DC plate voltage on the other side alternates below the coupling cap's charged voltage, the coupling cap will discharge through RL until the plate voltage alternates upward with input signal and recharges the coupling cap. It is this charge/discharge action that becomes your final output signal.
And yes...small value coupling caps will not fully charge/discharge below certain frequencies. This is why lower value coupling caps have a low frequency "roll off"....in other words, the low frequencies they pass will be at a lower amplitude than higher frequencies because the cap cannot fully charge/discharge at those frequencies. The value of RL plays a part in this as it draws current from the coupling cap, and the coupling cap cannot maintain its voltage long enough for the low frequency alternating DC to recharge it back up fully.
