12xxx Larry Ground
rockstah
Re: 12xxx Larry Ground
Post by rockstah » Mon Feb 14, 2011 11:19 am
axeman wrote:AC Cord or AC/IEC? BTW the front face plate will have the JMP on it and the rear face pate will have Super Lead 100 and all the other warning caution stuff you would normaly see on the back. :scratch:
plan on beating Nik's price at Ceriatone. ;)
axeman
Post by axeman » Mon Feb 14, 2011 12:03 pm
I think I hijacked this thread. Sorry I'll start a new one. Mark it all depends on how many cihassis I get build.
vanhalen5150
Post by vanhalen5150 » Fri Feb 18, 2011 9:00 am
Just looking at my left over wire from George's kits. Is the black and red heater wire the same gauge as the rest of the colored stuff?
axeman
Post by axeman » Fri Feb 18, 2011 1:25 pm
They should be. 22g. top coat.
vh junkie
Post by vh junkie » Fri Feb 18, 2011 6:00 pm
I see a lotta folks say you should use 18 for the heaters, but 22 seems to work just fine. I am waiting for a run of wire in all colors... I will keep you guys posted.
I have sourced some larger 3A diodes (Regular and FREDs) for some of you guys. I (and Dave F.) recommend the regular diodes for the bridge and the smaller FRED for the bias. For the larger diodes wrap the parallel diodes around the outside of the posts(I messed up on one), and the X diodes over the top.
Axeman hooked me up with some JJ 6CA7s, and they are working fine! Still need to do an ABC against the EH 6CA7s and my Sylvania 6CA7s....
- Gunny Highway
vanhalen5150
Post by vanhalen5150 » Sun Feb 20, 2011 10:00 am
Those are the diodes you sent me correct? Should have my brackets this week. I hope I get this PT tranny wired correctly.
Strat78
Post by Strat78 » Sun Feb 20, 2011 1:03 pm
Hold off a bit wiring that PT. I just wrote chris regarding the wiring of his T2562 PT. I might have mine hooked up wrong.
vanhalen5150 wrote:Those are the diodes you sent me correct? Should have my brackets this week. I hope I get this PT tranny wired correctly.
vanhalen5150
Post by vanhalen5150 » Sun Feb 20, 2011 2:47 pm
Ok. That PT is a little confusing.
vanhalen5150
Post by vanhalen5150 » Sun Feb 20, 2011 2:52 pm
Yeah, a power tube comparison would be great. You could reamp a clip using each set.
Strat78
Post by Strat78 » Sun Feb 20, 2011 3:01 pm
The Larry grounding makes for a clean looking set up. I sent some shots to Robert so he could have a look at the PT wiring. I'm trying to form the caps right now but the voltage seems to be too low.
vh junkie
Post by vh junkie » Sun Feb 20, 2011 4:34 pm
Everything looks fine to me... might be your voltages are out of sync because you have the PT center tap lifted to do the cap forming... it will work itself out!
- Gunny Highway
vanhalen5150
Post by vanhalen5150 » Mon Feb 21, 2011 6:48 am
That looks pretty good Srat78! That grounding really cleans things up as you say, especially around the pots. I'm trying to follow your wiring but its pretty hard with a wide angle shot. Where did you get that cap I see on Vol1? I also see you must have redrilled for the 2 bolts on CM's PT.
Post by Tone Slinger » Sun Feb 27, 2011 9:50 pm
As far as forming the caps, what do y'all reccomend ? I do not have a variac, so I cannot gradually raise the voltage every few hours or so. Will just firing it up on the wall voltage hurt anything ?
Strat78
Post by Strat78 » Sun Feb 27, 2011 11:38 pm
Read through this thread if you have not already:
http://forum.metroamp.com/viewtopic.php?f=4&t=8396" onclick="window.open(this.href);return false;
You've had the kit for over a year so those caps will definitely need proper forming. It's easy! You should also pick up a variac to have on hand for other things down the road. :D
Tone Slinger wrote:As far as forming the caps, what do y'all reccomend ? I do not have a variac, so I cannot gradually raise the voltage every few hours or so. Will just firing it up on the wall voltage hurt anything ?
vanhalen5150
Post by vanhalen5150 » Mon Feb 28, 2011 10:01 am
Strat78 wrote:Read through this thread if you have not already:
So did you do it the way Larry outlined or did you just pull out the tubes and use the variac?
