I'm writing here as I hope to get some insight on tweaking the infamous 12XXX and I'm sure this will inspire other builders to go ahead and experiment as well. The 12XXX at hand was built by myself about a year ago. I wanted one to get that van Halen Unchained sound I saw on Youtube (great video George!). However, my tastes have changed a bit since then and I'm now leaning more toward a cleaner sound. I thought at first that with a 100 watter I'd always have all the clean headroom I'd ever want but it actually ain't so... The amp gets into heavy crunch territory quite fast and now I would really want a LOUD clean sound. I would also love to increase the MIDS so that the amp cuts more through the mix (there's another guitar player in the band and he cuts more through the mix with his Fender Hot Rod than I do with my 12XXX!).
My B+ is 452V and the amp is biased at 70% with TAD E34LB-STR tubes.
So to you tweakers: have you got any tips on some things to change inside the amp to have more mids and most of all a cleaner sound?
Here is one pic of the amp board:
I have read somewhere that changing the values of these three circled caps (or taking the .68uF cap out altogether!) would change the amp's tone. But to what extent? What will increase/decrease? For instance what will happen if I take the .68uF out? What will happen if I change it and place a 330uF instead? Same thing with the 560pF caps... And what about the 0.0022uF cap? What happens if you change it to 0.022uF?
Thanks a lot to everyone! Glad this forum is back!
PS: Now, don't tell me I should sell it and build a JTM45/100 instead...
