Changing the output of a 100w SL
- ohmygodtheykilledkenny
Is it true that you can just remove the two outside power tubes in your quartet to lower the output of a 100w Plexi?
- rockstah
Re: Changing the output of a 100w SL
do a search here. there is a thread about using only one power tube!ohmygodtheykilledkenny wrote:Is it true that you can just remove the two outside power tubes in your quartet to lower the output of a 100w Plexi?
- Flames1950
