1/2 power layout
Brentsp
1/2 power layout
Post by Brentsp » Tue Nov 01, 2005 1:03 pm
I have the pentode/triode layout but would like to know how to do the actual 1/2 power by switching two of the tubes off/on.
Thanks in advance.
Billy Batz
Post by Billy Batz » Tue Nov 01, 2005 2:26 pm
You just lift the cathodes on the inner or outer pair.
Brentsp
Post by Brentsp » Tue Nov 01, 2005 2:33 pm
Billy Batz wrote:You just lift the cathodes on the inner or outer pair.
Thanks Dan, what pin is that? :oops:
And would it be just be two wires from the switch.....one for each tube?
Billy Batz
Post by Billy Batz » Tue Nov 01, 2005 2:56 pm
Pin8 and yes.
rockstah
Post by rockstah » Wed Nov 02, 2005 10:42 am
this sounds very kewl :)
Billy Batz
Post by Billy Batz » Wed Nov 02, 2005 11:38 am
Its not in any way a half power switch. At least as far as perceived volume is concerned. Your talkign like a 2-3db drop. And really all it gives you is a totally uneeded switch when you could just pull 2 tubes. But you can add it easily if you wanted it.
rjgtr
Post by rjgtr » Wed Nov 02, 2005 5:32 pm
I think the Pentode/Triode is generally more useful. To really lower the power, you'd need to lower the B+ to the power tubes like a lot of the old Musicman amps did.
Richard Johnson
