jackboy6
Post
by jackboy6 » Wed Jun 08, 2005 4:18 am
Hi George- please can u clarify this advice you gave ( I know from experience how important it is to break sozo's in!)
You can also remove the output tubes. Then run some dynamic signal through the amp with the standby ON.
Does this mean I can take the El34's out of my 1987 leave the anp on stanby -plugged into a speaker then say run music from a cd via a mixing desk?
many thanks
Nick
Post
by Flames1950 » Wed Jun 08, 2005 8:38 am
It won't work to leave the amp on standby, you have to switch the standby to the "on" playing position.
Otherwise you've got the right idea.
jackboy6
Post
by jackboy6 » Wed Jun 08, 2005 9:38 am
Thanks Flames- so it is ok to run the amp on with the EL34's taken out ?
( Just checking I have got the correct understanding)
cheers
Nick
gnugear
Post
by gnugear » Wed Jun 08, 2005 11:48 am
Yeah, that's the way I did it (no power tubes).
Gear:
'73 Super Lead
'70 Basketweave
- Site Owner
Post
by VelvetGeorge » Wed Jun 08, 2005 1:34 pm
Yes. No need for a speaker plugged in either. Just dime it and slam the input with signal. Something like a CD or radio station that changes dynamically.
This won't break in your new OT though.
jackboy8
Post
by jackboy8 » Thu Jun 09, 2005 8:50 am
Thanks George- already after only 10 hrs the amp sounds less harsh.
Please can anyone comment on what happens to new output trannies- do they get smoother and if yes after approx how long?
thanks
Nick
Guest
Post
by Guest » Sat Jun 18, 2005 11:40 am
You are probably wearing in your preamp tubes more so than breaking in your capacitors.
Dai H.
Post
by Dai H. » Sat Jun 18, 2005 12:41 pm
a most ideal use for your spare Sovtek pres...
Necrovore
Post
by Necrovore » Sat Jun 18, 2005 5:47 pm
Hmm ok I guess I should try to redo mine then as I just set the amp without running a signal through it.
myker
Post
by myker » Sat Jun 18, 2005 8:52 pm
the "BEST" way to break in your sozo capacitors is by playing your guitar through the amplifier.
thats my favorite part of completing a build, actually playing the damn thing!
mike
Necrovore
Post
by Necrovore » Sat Jun 18, 2005 10:09 pm
Ya, true! I'm actually really really liking the way my amp is sounding lately. It's not the EVH type grind that everytone seems to try to obtain, nor is it gritty as a 2203. Maybe the caps are finally starting to finish forming.
joshwilson3
Post
by joshwilson3 » Wed Jul 06, 2005 12:12 pm
Necrovore wrote:Ya, true! I'm actually really really liking the way my amp is sounding lately. It's not the EVH type grind that everytone seems to try to obtain, nor is it gritty as a 2203. Maybe the caps are finally starting to finish forming.
What did you upgrade, and with what?
thanks
