I need new swamper resistors
Eric Klinger
Post by Eric Klinger » Tue May 24, 2005 10:31 pm
I need new swamper resistors... in my '76 100W JMP MV they are 5.6k and there are four of them... one of them has a crack so I might as well replace all four... anyway what is the minimum wattage rating? Are 5.6k 1 watts ok for this? Or do I need some more girth?
Thanks.
Guest
Post by Guest » Tue May 24, 2005 11:03 pm
1/2 watt are enough.
Eric Klinger
Post by Eric Klinger » Thu May 26, 2005 1:03 am
Thank you.
OnTheFritz
Post by OnTheFritz » Thu May 26, 2005 1:16 am
I don't understand using 4 vs 2 that only go to the outside tubes.
My 79' 1959 has the 5.6k on all 4 tubes.
Anybody have a definitive answer for this?
I'm re-building this thing, and I've got the parts to do it either way.
Thanks,
Fritz
OnTheFritz
Post by OnTheFritz » Tue Jun 28, 2005 12:17 pm
Hey dudes, Just wanted to bump this topic back up, cause I don't quite get it.
I'm torn between which is the "right" way to do it. With 2 resistors, just the outside pair is "seeing that". Doesn't that cause some kind of imbalance?
I guess I don't really need to undertand it, I just want it to sound the best possible.
Any input would be appreciated.
Fritz
Post by VelvetGeorge » Tue Jun 28, 2005 1:16 pm
Fritz, those resistors roll off high frequencies. That's how they prevent occillation. You only want t roll off nough to stabilize the output section, without dulling the sound.
As it turns out, using them on the two outside tubes usually keeps things stable.
If not, you can try using (4) lower values. The higher the value, the lower the cut off frequency.
OnTheFritz
Post by OnTheFritz » Tue Jun 28, 2005 2:39 pm
Thanks George!
