Cap value for depth mod?
gnugear
Post by gnugear » Fri Jan 07, 2005 12:03 am
I forgot which value to use ... is it .002 or .0047? Or is it .022 and .047?
Gear:
'73 Super Lead
'70 Basketweave
Billy Batz
Post by Billy Batz » Fri Jan 07, 2005 2:17 pm
Would that be the Depth mod that soldano uses? We have a discussion goin on that could use some info about that in the DIY page.
5150loveeddie
Post by 5150loveeddie » Fri Jan 07, 2005 2:59 pm
.0047 Chris
Guest
Post by Guest » Wed Jan 12, 2005 6:46 pm
could someone show me a drawing of the depth mod??
mike
myker
Post by myker » Fri Jan 14, 2005 12:56 pm
that was me
mike
Billy Batz
Post by Billy Batz » Fri Jan 14, 2005 1:31 pm
Its basically the same as a presence knob only instead of running off frequencies to ground its in line with the NFB and the cap value youll probably want alot lower. gnu told me the Soldano Depth mod is just switching a .0047 in line with the NFB and out again. A resosnance control or deep knob can blend it in and out for more control like a twin to the presence knob that dials in bass instead of highs. You would wire a pot as a rheostat and solder the cap accross either end so that full down it bypasses the cap and full up the signal goes almost completely through. Kevin OConnor shows a 22n and 250k pot I think.
myker
Post by myker » Mon Jan 17, 2005 12:10 am
ok, thats the mod i thought it was. thanks.
been there done that lol...
always looking for the next great depth mod lol
mike
Guest
Post by Guest » Mon Jan 17, 2005 1:18 am
So what did you think of 'that'?
Billy Batz
Post by Billy Batz » Mon Jan 17, 2005 11:35 am
That was me.
myker
Post by myker » Thu Jan 20, 2005 11:53 am
kinda farty, but maybe with some more filtering would tighten up
mike
Billy Batz
Post by Billy Batz » Thu Jan 20, 2005 3:42 pm
What amp did you use it on?
myker
Post by myker » Fri Jan 21, 2005 11:18 am
i tried it on my 2204 clone. farty. i just went back through that amp, changed some pre-amp values, moved some things around. etc. now i have achieved more bass, and much more gain. putting 1uf caps on all of the cathodes has this thing growling. i think i will try the .0047 in series with the NFB loop with a switch. the most important thing that i noticed is how important it is to mount the 68k input resistor on the tube socket and run shielded cable to it. its a must.
as soon as i get this 18watter sold im gonna start on the slo build.
mike
myker
Post by myker » Sun Jan 23, 2005 11:08 pm
i tried the .0047uf cap in series with the nfb loop. volume killer!! something cant be right about that.
mike
Billy Batz
Post by Billy Batz » Mon Jan 24, 2005 8:01 am
That doesnt sound right. you have it before the NFB resistor right? If its reducing lower freq in the NFB that should make it louder in the lower freq in the output signal.
ANTHONNY
SOLDANO SLO MOD
Post by ANTHONNY » Mon Oct 10, 2005 9:19 am
PLEASE, ANYBODY HAS THE SCHEMATIC FOR SOLDANO DEPTH MOD? i DON´T UNDERSTAND IT...
