Forming filter caps
novosibir
Re: Forming filter caps
Post by novosibir » Wed Jul 22, 2009 11:43 am
Roe wrote:Larry - your Norwegian is pretty good!
Roe, "my" Norwegian is generated with the help of this site:
http://www.translation.paralink.com/" onclick="window.open(this.href);return false;
My 'personal' language knowledge only is German, English & Russian - and maybe a bit remaining Latin from school, but that's already been nearly 40 years ago :|
Larry
el34on11
Post by el34on11 » Mon Jul 27, 2009 8:28 pm
novosibir wrote: Before forming I put the caps (solder lugs upside) into hot water for about 20-30 minutes, to decristallize the electrolytic inside. It's similar as what you have to do with hard, old honey, to make it fluid again - and this pre procedure helps much to reduce the forming time.
Ouch - so many of my 'secrets' in only one post..... :mrgreen:
Larry
Larry THANKS for shairing your secrets!! :D
I just acquired 6 nos LCR caps which will be finding their way into a 2203 build very soon and want to know if it is a good idea to do this procedure prior to forming these caps. I will be forming them after the build is complete as per your instructions before I start the testing procedure. Once decristallized, how long will the electrolytic inside stay decristallized? If it is relavant these are from '93 and '95.
Thanks again for shairing your wisdome!!!!! :D
Derrick
LesPauls and Marshall's
novosibir
Post by novosibir » Mon Jul 27, 2009 9:36 pm
el34on11 wrote:... how long will the electrolytic inside stay decristallized?
After they're formed - by principle forever, if you're using the amp regularly and it doesn't reast longer than maybe 6 months.
el34on11 wrote:If it is relavant these are from '93 and '95.
Those were good years of the LCR's! My congrats!
My whole stash is from 1993 and they're part of the legendary British Voice of my amps.
Larry
el34on11
Post by el34on11 » Tue Jul 28, 2009 2:34 pm
Thanks Larry for the info.....
Do you ever worry about moisture getting under the outer "shrink wrap" on the caps or is this really not a problem?
Derrick
novosibir
Post by novosibir » Tue Jul 28, 2009 2:45 pm
el34on11 wrote:Do you ever worry about moisture getting under the outer "shrink wrap" on the caps or is this really not a problem?
No, never worried about it!
The shrink wrap is sitting so tight - and if nonetheless...
... the cap itself is sealed! So what?
Larry
el34on11
Post by el34on11 » Tue Jul 28, 2009 2:52 pm
OK Thanks....... :)
Derrick
el34on11
Post by el34on11 » Sun Aug 30, 2009 9:42 am
Hey Guys.....
Larry I need your help........ :oops: :oops: :oops:
Well I finished up my second 2203MV build, I used NOS LCR caps on this build so I thought I better use the forming procedure on this one as Larry suggested.
I'm using Hammond transformers 290HX Power, 1750U output and 194c choke. Specs for these transformers are here.....
http://www.hammondmfg.com/guitarLine.htm" onclick="window.open(this.href);return false;
I'm using Metro layout and chassis and most small parts...
Pics of chassis are here,how I was doing the reforming of the LCR caps....
http://s244.photobucket.com/albums/gg31 ... ng%202203/" onclick="window.open(this.href);return false;
O K well everything started out fine......Or so I thought... :oops:
298V accross the 100k at first fire up
Dropped to aprox 120V within about a minute or two
Was dropping steadly but slowly after that
It got to about 95V.....Aprox 5 minutes later
Then the power transformer got very very very HOT And had a MELT DOWN before I had realised what had happened and was able to shut the power off..... :oops: :oops: :x :oops: :oops:
Then it started smoking and oozing all kinds black stuff....It died a painfull death... :? :shock: :lol: :?
I know the power transformer is SCRAP now and has to be replaced, did I wreck my NOS caps???
Please look at the pics in the link and tell me if I have something wrong during the reforming prossess.. I will get a new transformer next week and have it changed out that is no problem.....
I don't know what the problem was that created the MELT DOWN I did make sure that none of the "tweaks" for forming were shorting to cause this as well.....
Could these caps have such high leakage to cause this? And are these caps going to be OK to start the reforming prossess over again once the transformer is replaced???
Thanks for any suggestions and help
Derrick
novosibir
Post by novosibir » Sun Aug 30, 2009 10:08 am
I wonder why the mains fuse didn't blew!
Did your metal clip from the B+ to the 100K short to the chassis by accident?
A eventually high leakage current of the LCR's can't be the colprit, because the 100K before is a huge current limiter.
Check for the reason! Short? Main fuse way too big?
But the LCR's can't be damaged, when the current source (PT) before goes down!
Larry
el34on11
Post by el34on11 » Sun Aug 30, 2009 11:09 am
Thanks for the help Larry.....
novosibir wrote:I wonder why the mains fuse didn't blew!
Mains fuse is still OK didnt blow....I was wondering this myself :?
novosibir wrote: Main fuse way too big?
I have a 4amp slo blow in there,and a 1amp slo blow for the H.T.fuse, I think those are the correct values. Double checked the stamping on the fuse to make sure.
novosibir wrote: Did your metal clip from the B+ to the 100K short to the chassis by accident?
Larry I am sure that the clip didnt touch any part of the chassis,also not seen in the pictures i did have the clips protected with electrical tape while forming
novosibir wrote: Check for the reason! Short? Main fuse way too big?
Ok I've checked to make sure nothing visable was shorted,pulled the board back up to make sure there was no pinched wires, I did recheck the voltage switch and I have continuity between all terminals (i think this is because the transformer has melted down tho)...
Could it have been a bad switch or maybe a bad transformer that caused this?
I'm pretty sure that there were no visable shorts and the transformer was wired correctly,any suggestions where I can start looking for shorts?
Thanks for your help!!!!
Derrick
novosibir
Post by novosibir » Sun Aug 30, 2009 11:22 am
I think, that after that all it's simply been a bad PT, who has eaten itself.
Probably a manufacturer's fault?
Swap in another one and start again.
Larry
el34on11
Post by el34on11 » Sun Aug 30, 2009 12:32 pm
Thanks Larry
I'll have the new transformer by the end of next week. I'll make sure I pay closer attention to see if the new transformer is getting hot!!!
Even tho I'm out a brand new transformer I'm feeling better that I didn't do something wrong to cause the melt down.....
I'm going to pull this one appart and have a look inside, even tho I dont think I will I will find anything.......I just have to look :lol:
Thanks again for your help Larry
Derrick
el34on11
Post by el34on11 » Sun Aug 30, 2009 4:31 pm
Well here it is........... :shock: :cry:
(90.18 KiB) Downloaded 1056 times
Primary side shorted out...... :cry:
It releised all it's "magic electrical smoke" and now its dead! :lol: :shock: :lol: BTW it is the worst smell ever....... :shock: :lol: :roll:
Too bad there is "no refunds or exchanges on electrical products"
Derrick
Structo
Post by Structo » Sun Aug 30, 2009 6:22 pm
Yep, once you smell that smell you will always remember it.
Which is kind of good in a way because if you ever smell it again you will reach for the power switch very fast. :wink:
Tom
Don't let that smoke out!
Greazygeo
Post by Greazygeo » Tue Sep 01, 2009 10:19 am
I'm getting ready to try this on my 1959RR. It has bleeder resistors on 4 of the filter caps. Do I need to unsolder all of them or just the two that were mentioned?
novosibir
Post by novosibir » Tue Sep 01, 2009 10:53 am
Greazygeo wrote:It has bleeder resistors on 4 of the filter caps.
If thee are two across the 1-st filter caps, then they anyway have to be removed entirely, cos they aren't there original.
Check, whether there's an orig. PT in the amp with the yello CT from the HT secondary, what is going between the 1-st filters!
Larry
